Run XnView from USB key?
ghost zero
Is it possible to run XnView with personal settings from a USB key? Or does the program have to be actually installed on a particular computer?
Re: Run XnView from USB key?
No you can use it, store db+settings in application folderghost zero wrote:Is it possible to run XnView with personal settings from a USB key? Or does the program have to be actually installed on a particular computer?
Troken
- Forum Librarian
JuergenK
I have got an U3-USB stick from verbatim (also available from other vendors). The stick comes with the U3 software installed, it automatically starts an application called "Launchpad". It add it's own kind of start menu. In this menu you will find a "add programs" function. This connects you to the U3 download portal. Here you'll find XnView. Installation is just one click.
