Image quality
Photure
Image quality
Post by Photure »
XnView is a great program and it could be The Best if the image quality in viewing mode would be of the same high level as ACDSee.
Images viewed with ACDSee look a lot better and I was wondering if this would be possible in future releases of XnView without the loss of the high speed XnView now has?
In that case I would certainly prefer XnView above ACDSee :!: :!: :!:
Regards, Photure
Re: Image quality
Do you have tried to enable zoom high quality/reduce?
Photure
Re: Image quality
Post by Photure »
xnview wrote:Do you have tried to enable zoom high quality/reduce?
Hello Pierrre,
Thanks for your reply, that's the solution! Image quality is now the same as in ACDSee!
I couldn't find this setting because my interface language is Dutch..... :?
Regards, Photure
Dstruct
Re: Image quality
Post by Dstruct »
Is it possible to improve the speed of the high quality zoom mode? It's too slow for me on an Intel E6700 Dualcore 2,66 GHz.
oops66
Re: Image quality
Post by oops66 »
Yes, I agree too !
Calculate only the area that is really showed in the window for high quality zoom.
Is this good request (from Olivier_G) already applied into the v1.93.6 ? :
http://newsgroup.xnview.com/viewtopic.p ... ht+quality
http://newsgroup.xnview.com/viewtopic.php?p=7190#7190
Photure
Re: Image quality
Post by Photure »
High quality zoom works fine on my (new) computer, don't have problems at all....
oops66
Re: Image quality & improve speed of the high quality zo
Post by oops66 »
Yes, the High quality zoom (in view mode) works fine but it can be faster with this Olivier 's suggestion, especially for olds computers and/or larges images files (in MB) with a high zoom factor, it's worst.
With that ?
:arrow: oopps66
:) Hello !
• Another approach helpful for HQ zoom speed should be to get the feature required by the user Peter2,
and for which I proposed THAT MOCK-UP
• Supposing that you blow up the useful area only (as HQ), you indeed save a lot of memory,
and might get the motif as blown up much faster than currently…
- Just a thought.
:mrgreen:
oops66
Re: With that ?
Post by oops66 »
Clo wrote::arrow: oopps66
:) Hello !
- Just a thought.
:mrgreen:
Hello Clo,
This specific other function (magnifying glass into a predefined area) is a good idea too, both are possible, but personally I prefer a more ergonomic behavior, because it's more natural with the mouse.
What is Pierre's opinion ?
oops66
Re: With that ?
Post by oops66 »
For information (testing) you can try this on your computer too ( options\View\ high quality zoom checked, and change zoom in fixed steps=99 ):
On my computer and with a 1280x1024 (1.25MP*) jpg 24bits file into the View mode:
(*with a fast computer you can do this test with a 10Mpixels file)
1-)first step zoom in view mode (mouse wheel or hotkey "+") = CPU 80% ~1/2 second
2-)second step = CPU 100% ~1.5 second
3-)step = CPU 100% ~4 seconds
4-)step = CPU 100% ~5 seconds
5-)step = CPU 100% ~8 seconds
6-)step = CPU 100% ~11 seconds
7-)step = CPU 100% ~15 seconds
8-)step = CPU 100% ~18 seconds
........then 63 seconds for only 8 steps (at 99) with a small jpg (1.25 Mpixels only).
It's what why i don't use this high quality zoom function under xnview.
What are your values ????
An idea about: to calculate only the area that is really showed in the window for high quality zoom steps.
This could be done by a new hidden function ( catch the mouse position, calculate the area with the "change zoom in fixed steps" value around the mouse position, use the Crop function "shift+x", and full screen zoom function hotkey "/"), then it will be very fast especially on large MPixels files too.
________________________________________________________________
Pierre, is it also possible to allow steep values higher than 99 ? , because it's not possible into the v1.93.6.
Re: With that ?
oops66 wrote: An idea about: to calculate only the area that is really showed in the window for high quality zoom steps.
I've made such feature in XnView MP, so when i'll release a new alpha, please check if it's better...
oops66
Re: With that ?
Post by oops66 »
OK, Great !
I am already sure than it will be better.
Thanks Pierre.
JohnFredC
Post by JohnFredC »
John
oops66
Post by oops66 »
Yes JohnFredC, same problems then same solution(s) !
By this way (calculate only the utile area for the high quality zoom & consider as "temporary garbage" for each steps zoom the rest of the image to improve the rapidity) even the Clo's suggestion (magnifying glass into a predefined area) could be done easy & quickly with a personal hotkey & a custom area setting for example.
I hope this change will be also implemented into the Win version later, (not only for the MP version) if Pierre has enough time !
oops66
high quality zoom
Post by oops66 »
Hello Pierre,
When will the new MP alfa version will come up, or, because I have downloaded the MP version today, to try the high quality zoom but ....
