Jpeg2000 error on bigger files?
DilSpi
Post by DilSpi »
i made a snappie with the second life (SL) client, which can do JPEG2000 files.
I can open the file in Adobes Photoshop elements without problems.
But with XnView i can only open files up to a size of 1992x1494.
I opend a ticket at SL, cause i first dont get, that other programms open j2c's correct and maybe SL write files in a not so a formal strict way.
Ticket: https://jira.secondlife.com/browse/VWR-3018
I attached a test-file: https://jira.secondlife.com/secure/atta ... 7a_004.j2c
Ciao :)
DilSpi
Re: Jpeg2000 error on bigger files?
Which JPEG2000 plugin do you use? With Xjp2.dll, i can open it
Post by Guest »
xnview wrote:Which JPEG2000 plugin do you use? With Xjp2.dll, i can open it
Im not so sure where to find that, but if its the right place, i use it too.
In XNview-menu under info i see it under plug-in-information and in the program directory under plug-in i have a file with that name and the version number 1.93.6 RC1 (unstable).
environment:
winXP professionell, Service Pack 3, german,
i work only with user rights ...
... and as i wrote this, i think maybe xnView dont like users? - I made the test and logged in with admin-rights. I can read the file now too.
So it maybe a permission-problem.
But only on bigger j2c-files? or is it my dayly-user-account? i will try it with an new fresh account to read the file.
Ciao :)
DilSpi
DilSpi
Post by DilSpi »
Im not so sure...
Sorry that were me too.
But i did the test and think i came closer to the point.
Other user-account didnt help, cause XNview seams to write direct on c:\
I used filemon under my admin-account, to look for and got many of this lines:
1953 23:33:22 xnview.exe:4540 WRITE C:\s4ds.c SUCCESS Offset: 509600 Length: 5600
1954 23:33:22 xnview.exe:4540 WRITE C:\s4ds.c SUCCESS Offset: 515200 Length: 5600
1955 23:33:22 xnview.exe:4540 READ C: SUCCESS Offset: 524288 Length: 4096
1956 23:33:22 xnview.exe:4540 WRITE C:\s4ds.c SUCCESS Offset: 520800 Length: 5600
And some of this lines:
331 23:33:12 xnview.exe:4540 QUERY INFORMATION C:\WINDOWS\system32\DXGI.DLL FILE NOT FOUND Attributes: Error
332 23:33:12 xnview.exe:4540 QUERY INFORMATION C:\WINDOWS\system32\D3D10.DLL FILE NOT FOUND Attributes: Error
But this is maybe because i dont have directX10 on my windows XP.
Ciao :)
DilSpi
Dstruct
Post by Dstruct »
DilSpi
Post by DilSpi »
Dstruct wrote:maybe related to this: http://newsgroup.xnview.com/viewtopic.php?t=15025
yes looks a bit like.
I answert your http://newsgroup.xnview.com/viewtopic.php?p=62851#62851
Ciao :)
DilSpi
DilSpi
Post by DilSpi »
i tried the jpeg2000 plugin from the XnView 1.94 beta 1 package.
It looks like it has the same behavior, on bigger jpeg 2000 files it shows also only hex.
Ciao
DilSpi
