wildcard support for batch processing
bugmenot
Post by bugmenot »
I would like to use a wildcard for the input section.
For example, I want to convert all files in a folder but filenames may be different each time.
Re: wildcard support for batch processing
Sorry but i don't understand what you want to do?
bugmenot
Post by bugmenot »
When you add a folder to Input, XnView adds the files in that folder:
I would like to do this (or something similar):
No need
:arrow: bugmenot
:) Hello !
• To convert all files of a directory, use the button [Add folder], then all files will be in the “Input” list.
- There is no need to type i.e. Path…\Folder\*.* doing so.
:mrgreen: KR
bugmenot
Post by bugmenot »
Yes I know that but I would have to do that every time I want to batch process some images.
What I want to do is create a batch processing script for the files in a folder, but the files may change names so I need a wildcard.
Hmm, there's no wildcards at the moment. But pressing "Ctrl+A" and then "Ctrl+U" might be a simple workaround to achieve your behaviour. (Ctrl+A selects all files and Ctrl+U will open Batch processing).
bugmenot
Post by bugmenot »
helmut wrote:Hmm, there's no wildcards at the moment.
Hence why I posted a feature request :D
Sure. What about the suggested workaround? Is it applicable?
And perhaps even simpler:
When changing setting "Convert" in Tools > Options > General > Misc. to "Convert=Use all images in current folder" all image files will be used by default as long as no selection has been made by the user.
bugmenot
Post by bugmenot »
I have to start XnView in browser mode but it does work for now. Thanks.
