Print / "Single Custom"
Peter2
Post by Peter2 »
I have a B/W TIFF, 20.87x29.65cm (A4, Portrait). My printer settings are A4-portrait.
My units are "cm", NO option "Maintain aspect ratio"
Command "Print" - Layout - "Single-Custom"
I activate "Automatic rotate" and enter "Width 21, Height 29.7" -> the preview is rotated 90° ???.
I disable automatic rotate -> the preview is OK..
I change Width/height -> OK witout Rotating. Not OK with Rotating
Seem to be a problem in connection "Rotate / Mainatin aspect ratio".?
Command "Print" - Layout - "Single-Scale"
I use X = 1.2, Y = 0.3, rotate automatic -> but there is no rotation (where I think it should be ...)
If I set "X=100" and "Y=100", it scales "only" to "max. fit on page" (Scale 1.1), but in the edit box is displayed "100 / 100". It should display the real scale-value.
Peter
Peter2
Post by Peter2 »
Can someone confirm - or disagree with - these problems?
Peter
Peter2
Post by Peter2 »
Hello
push up again ...
Peter
i'll check
