B2: High quality in slide show doesn't work
Dreamer
Post by Dreamer »
I see no difference if this option is enabled, or disabled.
Here is the same image with resolution 320x240 enlarged to 640x480 in xnview - edit mode and in the slide show:
Dreamer
Re: B2: High quality in slide show doesn't work
Dreamer wrote:I see no difference if this option is enabled, or disabled.
I think that you have that with old version too, high quality is only for reduce
Dreamer
Post by Dreamer »
Yes, but it looks really awful on some pictures, much worse than on my screenshot. Could you add HQ also for enlarge please? Or it would be too slow?
Result when using option "stretch small pictures" is really bad, so the HQ should be enabled also for enlarge IMHO - even if it would be slow - it doesn't matter so much in slide show.
Dreamer
Dreamer
Post by Dreamer »
Still the same in v1.94.
Moved to Bug Reports.
Dreamer
