Duplicated Default Categories
Currently, I have many duplicates of the default categories: E.g. "Fotografien" four times, "Videos" even six times.
The problem occurs on at least two computers. Perhaps the problem has to do with the installation of new versions and/or the manual deletion of .ini file.
Do other users have the default categories duplicated, too?
oops66
Re: Duplicated Default Categories
Post by oops66 »
helmut wrote:...
Hello helmut,
Yes, I had this problem too (under Windows 98 SE) but it's normally fixed now since V 1.91.5 !
http://newsgroup.xnview.com/viewtopic.p ... t=category
(from in French : http://newsgroup.xnview.com/viewtopic.php?t=13305)
Peter2
Post by Peter2 »
helmut wrote:...Do other users have the default categories duplicated, too?
Yes - I found it too on some machine, but I did not care because we don't need it.
Peter
Thank you for your feedback, oops666 and Peter2. Good to read that this problem is supposed to be fixed. I'll delete the duplicate categories and will observe this.
Peter2
Post by Peter2 »
Helmut,
anything new? I have some PCs where some entry appears 5 times - and in two languages too ...
Peter
The problem is supposed to be fixed (see oops66's post with link above).
