Hi, I'm wondering if it's possible to change ratings from fullscreen or "opened" mode. I can't find the option through any of the menus and the ctrl+numpad hotkey doesn't work in those modes. It seems the only way it is possible is from the thumbnail view, which is inconvenient to access when I am browsing through a folder in fullscreen.
I would prefer to use the numpad hotkey but if it is available from a menu that would be fine too.
Also, is it possible to automatically display the "info" text in the "open" (not fullscreen) view without pressing I every single time?
Change ratings from fullscreen mode?
- Forum Librarian
GeorgD
Re: Change ratings from fullscreen mode?
Both is possible (rate in fullscreen and using hotkey), see http://newsgroup.xnview.com/viewtopic.p ... 556#p78550gave wrote:It seems the only way it is possible is from the thumbnail view, which is inconvenient to access when I am browsing through a folder in fullscreen. I would prefer to use the numpad hotkey but if it is available from a menu that would be fine too.
In the XnView Wiki, you can improve the user guide / documentation / F1-help for XnView (classic/Windows) and for XnViewMP
