can not support unicode?
ALAEN
Post by ALAEN »
Hello everyone~
Can XnView add a plug-ins to support unicode?
Thanks :P
No plug-in
:arrow: ALAEN
:) Hello !
• XnView doesn't support Unicode (yet), and that can't be solved with any plug-in…
- That needs to rewrite almost the whole codes, not a piece of cake.
• It's indeed planned for a future version, but only the (single) Author can tell you when that starts…
- The Multi Platform version (on Alpha stage currently) supports Unicode, please see its section here in the forum.
:mrgreen: Kind regards,
ALAEN
Re: No plug-in
Post by ALAEN »
Clo wrote::arrow: ALAEN
:) Hello !
so...
when it can support?
i love xnview very much~ :wink:
but it can not support unicode...it is so pity... :(
Thanks :mrgreen:
dslam
No Chinese without Unicode
Post by dslam »
Hi, just wanted to add to the fact that you cant read files with Chinese characters in the name without unicode.
I used to work at a software company, so I know that implementing unicode is no small task. I hope that it can be done soon though so that I can look at my files and folders with Chinese words.
Thanks for the great program!
J
