Saving B/W image results in large file
PeterMo
Post by PeterMo »
I make a image for PhotoMasque Mask by Windows Paint(the color of image just black and white) and I save it as bmp
Then I fomat the bmp image to jpg(use 100% Quality) by XnView, but the size of result is too big...
THANKS :?
Re: Why your image is too smell and my image is too big...
JPEG doens't support b&W format, but you can try greyscale
