F4 key to open a local program?
nachfrage
Post by nachfrage »
I like to start a program over a shortcut. On my system is no function, when I press the “F4” button. Is it possible, to make a connection between the button “F4” and my own program ?
Best regards
heinz
Re: Can I make a connection from F4 to a local program?
F4 use default editor from windows explorer
nachfrage
Post by nachfrage »
Thanks.
Is there a possibility to make a connection between a shortcut and a other picture editor?
best regards
heinz
nachfrage wrote: Is there a possibility to make a connection between a shortcut and a other picture editor?
You have open with (Atl+1/2/...)
nachfrage
Post by nachfrage »
Thanks, work fine.
Is also a possibility to change that shortcut?
Besr regards
heinz
nachfrage wrote: Is also a possibility to change that shortcut?
Not currently
