dglp
Posts: 28 Joined: Mon May 19, 2008 11:37 am
Post
by dglp » Wed Jul 30, 2008 9:35 pm
For about two weeks I've been unable to open XnView other than by selecting an image and using the contect menu to 'Open with...'.
If I use the shortcut or if I go directly to the .exe, I get this error message while it's starting:
Similarly, if I have opened using an image, but select Browse view, it gives the same error.
Posts: 8704 Joined: Sun Oct 12, 2003 6:47 pm
Post
by helmut » Thu Jul 31, 2008 12:12 am
Perhaps your program file got corrupted for some reason. Or the thumbnail cache might contain invalid data. Or XnView starts up in a directory with a corrupted image which crashes XnView.
Could you please uninstall and reinstall XnView and see if the problem persists?
Posts: 48933 Joined: Mon Oct 13, 2003 7:31 am
Post
by xnview » Thu Jul 31, 2008 6:32 am
Please try to drag&drop a picture file to xnview icon. Does this crash, too?
Post
by Guest » Thu Jul 31, 2008 7:53 am
Okay. Is there anything I should do aside from making a backup copy of the database?
dglp
Post
by dglp » Thu Jul 31, 2008 8:07 am
xnview wrote: Please try to drag&drop a picture file to xnview icon. Does this crash, too?
Pierre, this process works fine with the four images I tried. It also allows the Browser function. Does that help pinpoint the problem?
David
Post
by xnview » Thu Jul 31, 2008 9:10 am
dglp wrote: xnview wrote: Please try to drag&drop a picture file to xnview icon. Does this crash, too?
Does the browser start in the same directory as your four images?
dglp
Post
by dglp » Thu Jul 31, 2008 5:25 pm
xnview wrote: Does the browser start in the same directory as your four images?
Yes it does.
Post
by xnview » Fri Aug 01, 2008 6:46 am
dglp wrote: Yes it does.
And if you restart xnview, the browser start in the same directory and crash, right?
dglp
Post
by dglp » Fri Aug 01, 2008 7:15 am
If I start by clicking the shortcut, it crashes immediately, before the program window appears.
Post
by xnview » Fri Aug 01, 2008 7:24 am
Have you tried to remove xnview.ini? xnview.db?
Do you have only jpeg files in this folder?
dglp
Post
by dglp » Fri Aug 01, 2008 3:36 pm
I haven't removed anything yet, but am ready to do so if that's the next step you'd suggest.
