How to open image from XnView to another Photo Editor?
Strumpf
Post by Strumpf »
Hi, i am using XnView for browsing organizing, classify, my fotos, and to do some small corections.
Later i open picture in PhotoEditor which is not Photoshop, so...
is it possibile to import picture directly from XnView to The Gimp, for example?
Note, i want that XnView is still default Image viewer
Strumpf
Post by Strumpf »
Sorry for bothering, i just found it, after reading some other topics here
so its enough to go Tools/open with/add program...
Hi is so smart, so it assign automaticly shortcut key ALT+1, ALT+2(for second added program), thats more cool than i hoped
:D
Tony
Re: How to open image from XnView to another Photo Editor?
Post by Tony »
While working on an image in XNview, it is automatically held in a temporary folder as a BMP (example C:\Documents and Settings\~\Local Settings\Temp\test2.png.bmp). If I want to use 'File/Open with', the target application opens a BMP. This is OK unless you want to pass on transparency. Is there a setting that allows temporary images to be saved automatically as PNG instead of BMP?
Tony wrote:While working on an image in XNview, it is automatically held in a temporary folder as a BMP (example C:\Documents and Settings\~\Local Settings\Temp\test2.png.bmp). If I want to use 'File/Open with', the target application opens a BMP. This is OK unless you want to pass on transparency. Is there a setting that allows temporary images to be saved automatically as PNG instead of BMP?
I'll add a setting
Tony
Post by Tony »
Thank you.
