Thumbnail click detection sometimes incorrect!
ghost zero
Post by ghost zero »
1.94.2
Thumbnail click detection is sometimes incorrect. When clicking near the left or right inside edge of a thumbnail, sometimes the nearby thumbnail is mistakenly selected instead of the clicked one. Can this be fixed?
BTW: I have thumbnail size set to 100x100.
"Binary" size ?
:arrow: ghost zero
:) Hello !
• I could not reproduce that issue here, maybe because I use a 96² thumb nail size (which matches a ² binary value…).
:mrgreen: VG
ghost zero
here's my ini file in case it helps...
http://www.sendspace.com/file/863asn
Space & border ?
:arrow: ghost zero
:) Again…
• In your INI, I notice that you have “0” for the spacing and the border…
- What does occur with let's say, 1 pixel at the two ?
- Here, I've :
BorderSize=2
Spacing=3
:mrgreen: VG
ghost zero
i like having the spacing set at 0. does the problem occur for you with my ini?
OK with yours
:arrow: ghost zero
:) Again…
…does the problem occur for you with my ini?
• No, it doesn't, I have still a kind of thin “neutral” area between the thumb nails
before to get the neighbour one activated when clicking…
:? Wait and see whether some other users will be able to reproduce…
:mrgreen: VG
ouistiti
Post by ouistiti »
:arrow: ghost zero
No problem here either using your INI.
- I guess that it isn't XnView-related, but it could be caused by your mouse-cursor
(some cursors having the “hotspot” badly located).
- Maybe could you try another cursor (or edit yours and check the hotspot location, i.e. in GFIE…) ?
Friendly
Paul
1,77245385090552... •
