Less then / equal / More than in Search
vladivostok
Post by vladivostok »
When I select for example "More than 1600 width" in the search dialogue, it also lists those images, which exactly have 1600 pixel width.
Actually this term is incorrect. Label must be "At least", or it must not list the 1600 width images also.
Re: Less then / equal / More than in Search
vladivostok wrote:When I select for example "More than 1600 width" in the search dialogue, it also lists those images, which exactly have 1600 pixel width.
What is the best? Changing label for "At least" or not have equality?
xnview wrote:...
I'm not native speaker but "At least" sounds clumsy to me. And what's the opposite? Hmm, perhaps "With a minimum of" and "With a maximum of" might work, but again clumsy. :-|
Currently I'd prefer "More than" or "Less than" and have no equality.
Peter2
Post by Peter2 »
helmut wrote:...Currently I'd prefer "More than" or "Less than" and have no equality.
Yes, that is correct. If the user looks for "size equal or greater 1600", he has to type in "greater then 1599". That is the best way.
Peter
