in 1.95b2:
export
an adobeRGB TIFF to jp2: image displayed properly, color space probably kept.
save
convert
an adobeRGB TIFF to jp2: image displayed falsely (like an adobeRGB interpreted as a sRGB) color space probably lost
I say "probably" because you can't see the ICC in the properties panel for jp2s.
So there is no way to keep the color profile while batch-converting?
1.95: ICC lost/kept
Troken
Re: ICC lost/kept
Whoa... have you experimented with, say, adobeRGB TIFF to JPG?darrask wrote:in 1.95b2:
export
save
convert
darrask
Re: ICC lost/kept
Yes, currently the profile is applied at the loading, so can't be kept when saving the picture.darrask wrote:So there is no way to keep the color profile while batch-converting?
darrask
Oh, I get it. So pictures are not completely loaded when we do a conversion from the thumbnail viewer, it is only when we open and load them in the viewer that the profile can be used.
But I still don't get why XV 1.93.6kept the profile for conversion also... ( http://newsgroup.xnview.com/viewtopic.p ... highlight= )
darrask
color space info lost
This is a new problem but the topic title would be exactly the same:
In 1.95.4, I have a TIFF which XV says it is in adobeRGB. If exported or saved as, the resulting images do not display the color space information anymore in the properties tab, although they keep the correct color space.
And if converted (Ctrl+U), well they truly lose their color space, but that we already know
Re: color space info lost
ICC is in 1.95 never kept
Troken
Not kept? So any editing of an image will discard the ICC???xnview wrote:ICC is in 1.95 never kept
Yes, it's currently a problem, i'll fix it in 1.96Troken wrote:Not kept? So any editing of an image will discard the ICC???xnview wrote:ICC is in 1.95 never kept
darrask
Troken
