using xnview over network-where do deleted files go?
Post by Guest »
i store my pics on a shared network folder, and when i delete pics directly from that computer, then it goes in the recycled bin, but when i delete pics (from the shared folder) from another computer, i can't seem to find where the deleted items go.
thanks for all your help and this great program!
Re: using xnview over network-where do deleted files go?
i think that windows delete it and not move it in recycle bin
Drahken
Post by Drahken »
Have you checked both the recycle bin on the computer where the shared folder exists & the recycle bin on the local computer you're using at the time? I know whenever I delete pics from a digital camera while it's connected to the pc, it sends the deleted files to the recycle bin on the pc.
rra
Post by rra »
I am afraid that your networkfiles are "completely" deleted,
the recycle bin will not be used, this is a windows issue, not so much an issue of XNVIEW.
see:
"http://en.wikipedia.org/wiki/Recycle_Bin_(Windows)"
under "Known issues".
René
