1.95 RC1 - Possible Edit IPTC City Bug
thecowboy
Post by thecowboy »
I just noticed that when I try to modify the city in the "Edit IPTC data" dialog that it always resets to whatever was previously located there upon pressing "write".
All the other location fields work as expected.
Re: 1.95 RC1 - Possible Edit IPTC City Bug
I can't confirm, 'update xmp' is checked?
oops66
Post by oops66 »
xnview wrote:I can't confirm, 'update xmp' is checked?
I can confirm this IPTC bug with "create or update XMP" checked.
1-) add a city \ write
2-) reopen crtl+i and try to change the city name \ write
then the bug occurs.
XnViewMP Linux X64 - Debian - X64
I can't reproduce, please send me a test file
oops66
Post by oops66 »
For example this image below:
Here, this bug occurs into this Origin tab, only if "create or update XMP" is checked, and only if i try to change these two fields:
city field (paris)
sublocation field (ccccc).
All the other location fields work as expected into this Origin tab for me.
So the problem is only with "create or update XMP"??
oops66
Post by oops66 »
xnview wrote:So the problem is only with "create or update XMP"??
Yes.
I have made a new complete IPTC test, and in fact, this bug occur also with some others fields for me, when "create or update XMP" is checked:
Origin tab:
City
Sublocation
Miss. tab:
Original transmission reference
Date / Time tab:
Date created(YYYYMMDD)
Time Created
(All the other fields, or keywords work as expected for me now, even if "create or update XMP" is checked)
And you can reproduce it now ?
See here too (1.95beta forum):
http://newsgroup.xnview.com/viewtopic.php?p=66746#66746
oops66 wrote: And you can reproduce it now ?
Yes now i have it
oops66
Post by oops66 »
Yes now i have it
Not fixed,
This bug remains into the v1.95 pre-release.
oops66 wrote:
Yes now i have it
Not fixed,
Really, all these fields??
oops66
Post by oops66 »
xnview wrote: Really, all these fields??
Yes, all the 5 fields above.
Ok, an error in the package. Replace http://www.xnview.com/beta/Xmp.zip
oops66
Re: 1.95 - IPTC Bug
Post by oops66 »
The problem persist into the final release v1.95 only for this field now:
Misc. tab:
