Hello
I think there should be a thread about that, but I did not found it...
Select a gif with transparency -> Ctrl-U -> Resize to 16x16, save as gif -> transparency is lost (gone to white)...
Bug or wrong setting?
Bruno
Transparency lost after resize
brotondi
Black or white…
• Confirmed here ! However, according to the image, the BG can turn all white -as you said - or all black…
- XnView 1.95 - XP-Pro SP1
ouistiti
brotondi
Nope
• Sorry, wrong, Paul above and I have the bug with a single image resized from the menu >> Dialogue, not in a batch !... well I think it will occur with every Batch-Save...
(not after manual editing and saving)
brotondi
ouistiti
- Open a GIF file, "add txt" in it -> all transparent gets black or white (without saving)
- Open an ICO file, "add txt" in it -> no bug
Paul
1,77245385090552... •
Re: Transparency lost after resize
The problem is when you resize a colors picture, the colors change so transparent index can not be kept
