Wish: color value info per mouse arrow
Micha
Post by Micha »
at the moment, if the mouse is moved over an open image the pixel coordinates are show at the upper border (x:.. y:..). It could be nice, if this field could be switched to show the color values like RGB or CMYK instead the coordinates.
Regards,
Micha
Troken
Post by Troken »
You can see colour information if you open your image and in the menu choose:
View / Display Colour Information
or Ctrl+Shift+I
Micha
Post by Micha »
Thank you for the hints. If possible, I would like to see the RGB infos instead the coordinates. Or maybe it possible to show both?
Micha wrote:Thank you for the hints. If possible, I would like to see the RGB infos instead the coordinates. Or maybe it possible to show both?
As suggested by Troken, please press Ctrl+Shift+i and move the mouse a bit, then you will see the colour info as tooltip.
If you want to have the colour info displayed always and not just for the current image, please see topic Show colour info not saved….
oops66
color picker - add (copy to clipboard / paste) function
Post by oops66 »
In an other hand, this function for me is not enough powerful, it would be also interesting with this function (color picker) to have the ability to copy the text result into the clipboard in case of left mouse click( for example), and not only inside the picture, but anywhere in the screen.
Then it will be very easy to paste the result into an other field or document.
Maybe with an other small (light) dedicated XnView stand alone executable: XnViewColorPicker.exe ? (like the stand alone XnViewMediaDetector.exe)
See here too, some others colors picker softwares:
http://newsgroup.xnview.com/viewtopic.p ... our+picker
http://www.annystudio.com/software/colorpicker/
http://www.iconico.com/colorpic/
