XnView Pocket v1.51
Discussions on XnView for PocketPC
XnView Pocket v1.51
The Foliator
Re: XnView Pocket v1.51
Post by The Foliator »
Great work, Pierre! I've given this version a thorough trial run on my Axim x51v, and the "display filename" bug fix is much appreciated. So are the two new features.
At first I thought that the gesture feature would interfere with the ability to drag a picture back and forth, but I was wrong. The feature isn't active when an image is zoomed.
RazR83
Post by RazR83 »
xnview, slideshow .exe do not work in new 1.51. :?
RazR83 wrote:xnview, slideshow .exe do not work in new 1.51. :?
Could you try this slide.exe
RazR83
Post by RazR83 »
xnview, much better - it works! Thx :D
Also works "slide.exe" from XnPocket 1.40.
Ok, i'll fix the current package...
eugene7
Post by eugene7 »
The option for showing images at full size (View, Original size) wont work until you have first viewed at least one image.
Can be a pain!
It would also be good if this option was remembered between shut-downs.
Thanks.
Steve
Steve Shaw
luisito
Post by luisito »
j'ai essayé en rajoutant le fichier ws2.dll, mais sans succès, malheureusement ... :(
luisito wrote:j'ai essayé en rajoutant le fichier ws2.dll, mais sans succès, malheureusement ... :(
Etrange, deja je ne comprends pas pourquoi vous devez rajouter les aygshell.dll, commctrl.dll, commdlg.dll, coredll.dll. Normalement tout est dans le repertoire windows de WinCE
AdminOfPlaygroup
Post by AdminOfPlaygroup »
C'est peut être un PNA (GPS) "cracké" avec une version allégée de Windows CE. Non ?
luisito
Post by luisito »
Qu'appelles-tu cracké ?? je ne comprends pas ??!! j'ai rien fait de spécial sur mon gps j'ai une version Windows CE version 5.0 build 1400
C'est quoi exactement comme modele?
eugene7
Post by eugene7 »
Any progress on fixing the 'view original size' issue?
Would be a real help for me,and others I would think.
Thanks in advance.
Steve Shaw
luisito
Post by luisito »
OUppsss désolé du retard :)
C'est un navigon 3100 que j'ai comme GPS, j'ai de nouveau essayé amis sans succès :(
freekgubbels
Post by freekgubbels »
hello
where can i download the 1.51 version of this great program?
I run 1.10 but since today the application crashes and doenst show the photos. Probably the new version will resolve these problems.
