Extracting movie frames on mpg files fails
avx
Post by avx »
I encounter a problem (with 1.95.3, 1.95.4, 1.96 beta2) on Windows XP SP2 when extracting movie frames:
It always only creates a black picture (tried gif and jpeg).
For avi's it works fine.
The mpg: 640x480 30fps
Re: extarcing movie frames on mpg files failes
Do you have the mpeg.dll?
avx
Post by avx »
in the xnview/PlugIns dir:
mpeg.dll 110.952 19.12.2007 16:08
At least I installed the 1.95.3 from the windows installer, afterwards I copied all files from the 1.96 beta2 zip to the program dir.
I've tried and no problem. Is it possible to have the mpeg file?
avx
Post by avx »
Hi Pierre,
you can download the snippet from http://www.wellenvogel.de/test/test.mpg.
I tried e.g. frame 999.
Regards
Andreas
obelisk
Post by obelisk »
movies never play correctly:
* the 1st time you enter the folder
* if thumbnail cache is unwritable and icon not cached
avx wrote:Hi Pierre,
Right, seeking in the mpeg doesn't work, i don't know why...
