Renaming filename or folder with '.' does not work
darrask
Post by darrask »
Under Options/Browser/Browser:
when "use dialog to rename files" is unchecked and "hide extension to rename" is checked, we cannot correctly rename files with a point in the filename.
It happens to me for a folder named "2000.07 Paris" for example. When renaming using F2, all that is after the point is considered to be the file extension and we cannot rename it.
vista SP1,
XV 1.96b2
Re: Renaming filename or folder with '.' does not work
Right but only for folder...
