Hy there,
how can i print to an exactly position on a CD-form.
The Position to print to is 1,6 cm from the top and 4,6 cm from the left side.
The print always go to 2,0 / 5,0 cm.
What is wrong in the program?
With IrfanView i have no problem!
Regards,
Print to exact Form
Re: Print to exact Form
You use Custom layout?atrost wrote: how can i print to an exactly position on a CD-form.
atrost
Sorry, the exact distance from left side is 4,2 cm and 1,2 from top to print to the CD-Label.
I scan a CD-Label and want to print to a CD-Label-Paper.
There are two labels on one DIN-A4 paper.
Each label is 4,6 cm from left side and 1,6 cm from the top.
After scanning in 300 DPI i have the print-layout-menu to "dpi". The printer layout is A4.
atrost
