How Do I Tag Photos In XnView? Help!
jaqian
Can anyone tell me how to tag photos in XnView? I presume it exists as I can see categories and that wouldn't be any good without tagging.
Also can anyone tell me how I can batch rename photos based on shoot date?
Thanks in advance,
Rob
Thanks in advance,
Rob
Re: How Do I Tag Photos In XnView? Help!
you would like to set categories for your files?jaqian wrote:Can anyone tell me how to tag photos in XnView? I presume it exists as I can see categories and that wouldn't be any good without tagging.
Batch renameAlso can anyone tell me how I can batch rename photos based on shoot date?
jaqian
No I wan't to apply tags, then later categorise them. For instance I would have a category "Family" and under that I would like to tag photos of my children as "Niamh" and "Daragh" etc.xnview wrote: you would like to set categories for your files?
I can see how to add or change categories but I don't see where I can add a tag (keyword) to a photo. Thanks.
You can drag&drop the file into the category, or in the preview panel you can check the category...
jaqian
RickS
jaqian
Thanks RickS, thats what I wanted to know, would have helped if I written it better from the get-goRickS wrote:You can tag with keywords in the IPTC data dialog box: Ctrl+Ijaqian wrote:Am I right in thinking then that there is no tagging only categories? Will the categories be saved to IPTC data?
You can search the IPTC data for those keywords: Ctrl+F
Can I tag multiple photos using Ctrl+I?
Troken
Sure, select multiple photos and use Ctrl+I.jaqian wrote:Thanks RickS, thats what I wanted to know, would have helped if I written it better from the get-goRickS wrote:You can tag with keywords in the IPTC data dialog box: Ctrl+Ijaqian wrote:Am I right in thinking then that there is no tagging only categories? Will the categories be saved to IPTC data?
By the way, you can create your own categories. For instance, you could create subcategories under "Family" - "Niamh" and "Daragh". Maybe that is what you're looking for?
jaqian
Thanks Troken.
No its definetely tags that I'm interested in and writing to IPTC, that way no matter what program I use down the road I will always be able to search by tag. I've many photos already tagged with Picasa but I'm not too fond of it, XnView looks really good and is constantly being updated as well.
My problem is that I've been taking digital photos since 2002 and haven't really organised them very well and am now trying to sort this out. And to ad to that I've scanned in most of the familys' photos. All told I've 50,000+ photos, which I'm trying to whip into shape!
I've decided to organise my photos in folders by date and then tag everything so that I an find what I'm looking for
Troken
Dreamer
It would be easier with the Face Recognition, Panasonic Lumix DMC-TZ7 has this feature, as well as the software from Panasonic...Troken wrote:Yes, Im a fan of IPTC too, since it is - as you mentioned - a standard and can be read by other software. Seems you've got a lot of work to do, good luck!
Panasonic Lumix DMC-TZ7 software
The portrait images taken with the camera’s Face Recognition function are organized neatly in the folder of the name registered with the camera. Not only that, the software also features an independent Face Recognition function that recognizes the faces in the picture stored in your PC to sort the photos by the face. You do not have to pick out each photo one by one out of thousand of photos when you only want pictures of a specific person. With PHOTOfunSTUDIO 3.0 HD Edition, the software automatically sorts your images into virtual folders based on the faces you registered. You can also enjoy slideshows with a variety of effects and use your iTunes music library as background music. Motion pictures can be uploaded directly to YouTube using the built-in YouTube uploader.
It would be a nice feature, don't you think? I'll start a new topic / suggestion, so you can support it, if you want.
Dreamer
pic_viewer
jaqian
I tried this last night and it wouldn't work when I selected 15 images but would when I selected only 6 or so, I was hoping to select 100sTroken wrote:Sure, select multiple photos and use Ctrl+I.jaqian wrote: Can I tag multiple photos using Ctrl+I?
Thanks Troken.Troken wrote: Seems you've got a lot of work to do, good luck!
Yeah that would be a nice feature alright, when are you bringing it outDreamer wrote:It would be easier with the Face Recognition, Panasonic Lumix DMC-TZ7 has this feature, as well as the software from Panasonic... It would be a nice feature, don't you think? I'll start a new topic / suggestion, so you can support it, if you want.
Troken
Yes, a current bug in 1.95.4Troken wrote:I tested to tag 24 images, works fine here. Can someone else please verify this?jaqian wrote: I tried this last night and it wouldn't work when I selected 15 images but would when I selected only 6 or so, I was hoping to select 100s![]()
BTW only JPG and TIF can make use of IPTC.
