Description:
XnView thumbnail details displays a bit-depth of 8 for JP2K files (with higher bit-depths according to XnView Properties) with the Lurawave JP2K plugin.
I have tried a clean reinstall of XnView, but continue to observe the same results.
Environment details:
- OS: Windows XP Professional SP3 (x86)
- XnView v1.96 Final
- - New XnView.ini
- - LuraWave.jp2 Dll v1.1.0.16
Workaround:
1. Temporarily remove "\Plugins\lwf_jp2.dll"
2. Generate/rebuild thumbnails for JP2 files (thumbnail cache enabled).
3. Restore "\Plugins\lwf_jp2.dll"
Question:
Is it possible to select/set a preferred plugin to use for reading when multiple plugins for a format are installed (eg. Jasper and Lurawave) ?
Thank you for creating XnView.
1.96: Incorrect bit-depth thumbnail detail for Lurawave JP2
Re: 1.96: Incorrect bit-depth thumbnail detail for Lurawave
Lurawave plugin load only on 8bits/componentAnonymous wrote: XnView thumbnail details displays a bit-depth of 8 for JP2K files (with higher bit-depths according to XnView Properties) with the Lurawave JP2K plugin.
Not possible...Is it possible to select/set a preferred plugin to use for reading when multiple plugins for a format are installed (eg. Jasper and Lurawave) ?
Why you don't use Jasper plugin?
Greetings,
Thank you for your corrospondence.
To verify:
In the Alt+Enter Properties->Image tab, of all of my JP2K files, it indicates (amongst other things):
Does the "8bits/component" refer to "Bits per Plane", "Bits per Pixel", or something else?xnview wrote:Lurawave plugin load only on 8bits/component
To verify:
- LuraWave JPEG-2000 Format
Bits per Plane: 8
# of Planes: 4
Bits per Pixel: 32
- Filename.jp2
LuraWave JPEG-200...
1600x1200x8
- Adobe Photoshop Document
Bits per Plane: 8
# of Planes: 4
Bits per Pixel: 32
- Filename.psd
Adobe Photoshop Do...
1280x1856x32
I used the LuraWave plugin instead because:xnview wrote:Why you don't use Jasper plugin?
- -The JP2 files seemed to load a little bit faster with the LuraWave plugin.
-Also, after reading what was written here http://newsgroup.xnview.com/viewtopic.php?p=62737#62737 I had the impression that the LuraWave plugin had more/better features than Jasper.
It's 8bits per plane or per componentAnonymous wrote:Does the "8bits/component" refer to "Bits per Plane", "Bits per Pixel", or something else?xnview wrote:Lurawave plugin load only on 8bits/component
