I have a folder with some web stuff in it. Lots of different HTML files and other types of files. One of the file types is a DWT extension. This is a template file of a web page. I edit and use the file in Adobe GoLive for creating web pages.
When I try to view this folder using XNView... it crashes every time. If I move the 2 DWT files somewhere else... there is no crash and I can view the folder.
Is this a known issue?
Thanks!
Crash With DWT Files?
Mike Truly
Sincerely,
Mike Truly
Truly Media
http://www.trulymedia.com
Mike Truly
Truly Media
Re: Crash With DWT Files?
Could you send me the files?
Mike Truly
Here is a link to a zipfile containing the DWT file.
http://www.trulymedia.com/issues/LCWMF_ ... mplate.zip
Thanks!
Thanks!
Sincerely,
Mike Truly
Truly Media
Mike Truly
Truly Media
Peter2
problems with Cadviewer?
DWT is also the extension for Autodesk/AutoCAD DraWing Templates which are displayed by the Cadviewer-plugin. maybe that is the reason for problems?
Peter
Peter
Mike Truly
Thanks for the ideas!... I bet that's the reason.
Sincerely,
Mike Truly
Truly Media
Mike Truly
Truly Media
Mike Truly
OK... I renamed the plugins folder and then XNView does not crash when I go to the directory with the DWT files in it.
Seems it's one of the plugins.
Thanks for testing this.
Sincerely,
Mike Truly
Truly Media
Mike Truly
Truly Media
Mike Truly
When I rename the CAD plugin... it doesn't crash so clearly this particular type of DWT file is confusing the plugin.
Thanks!
Thanks!
Sincerely,
Mike Truly
Truly Media
Mike Truly
Truly Media
Peter2
Hello
I think you both (Pierre and Mike) should contact the programmer of the Cadview-plugin. They released a new version of their main-software in January and plan to release a new viewer for TotalCommander in April. Maybe the can add a function in the viewer that controls the file-content before crashing ...
Main page:
http://www.cadsofttools.com/
Forum:
http://www.cadsofttools.com/forum/
Forum for XNView and TC viewers:
http://www.cadsofttools.com/forum/viewf ... 13d2f3c481
Peter
Main page:
Forum:
Peter
Mike Truly
Thanks Peter... done.
Sincerely,
Mike Truly
Truly Media
Mike Truly
Truly Media
