I want to move all my pictures to an external drive & keep the xn view categories. How to do this?
When I drag & drop or copy & paste via the xnview menu the files inside a given directory it works automatically: categories are copied together with the files.
When I copy an entire directory it doesn't work: directory is copied, files are copies but not the categories.
I would like to copy my complete photo directories (thousands of files) and avoid to have to copy the categories "file by file"
I tried different things but couldn't sort it out
Thanks for your help & sorry if this is a repost
Fred
How to copy categories when doing a massive copy
casoar
obelisk
Re: How to copy categories when doing a massive copy
You can't.
There was a request to copy categories into IPTC tags, but not implemented yet. Maybe if more ppl find it useful...
markdfink
I think you might find this post helpful:
http://newsgroup.xnview.com/viewtopic.php?f=35&t=17313
I have an external drive that I synch with an internal one. It's a question of setting the options to have all db files moved/copied, I think.
Mark
Mark
