Create Webpage: 'No thumb.html in Directory'
DamBuster
Post by DamBuster »
Hi I've a question - because I just returned from the home page because I have downloaded new version Xnview.
I just wanted to use the function of the webgalery and had to notice that only the default templates work.
If I use a different template folder [e.g. C:\XnView\WebTemplate\Visuddhi - Lightbox [red] ] with the click on the Select button , choose the wanted director and then click on START, I get the following error.
In this presentation folder is missing the file "thumb.html!" [/ B] (translated from German)
But there is a thumb.html file in the folder!
XnView can somehow just not open or find it.
Has anyone of you an idea?
Re: xnview - allways says: No thumb.html in Directory
The template path is C:\XnView\WebTemplate
c.wolke
Post by c.wolke »
thanks pierre, had the same issue. your answer was helpful!
strategia
Re: Create Webpage: 'No thumb.html in Directory'
Post by strategia »
I have the same problem as posted above that xn cannot see the html file in some of the template folders. But it has no problem in other template folders.
I didn't understand what Pierre meant (and I could not find any other folder for templates other than Program Files/XnView/Web Templates.
Also is there anywhere I can go to learn ow to modify/make templates for XnView?
strategia
Post by strategia »
Finally "the penny dropped" so I now know how to get the templates to work (thank you Pierre) but still interested to know about making/modifying templates, please
