UI-less Settings
Group for those who want to contribute to the Help file
Moderators: xnview, Ty
ckv
UI-less Settings
Post by ckv »
UI-less Settings documentation has been moved to the XnView wiki. --> http://wiki.xnview.com/index.php/UI-less_Settings
Re: UI-less Settings
:arrow: ckv
:) Hello !
• The most INI settings you quote here are already listed by chronological order and described HERE…
… and THERE for the colours per file type…
• It's still useful to track the obsolete¦missing ones though, and you may use our descriptions
(about the spelling ;) ).
:mrgreen: KR
marsh
Post by marsh »
Hello ckv,
some ShowAgain puzzle pieces:
2. Lossless jpeg operation notice,viewer.
128. Lossless jpeg operation notice, browser.
4096- Are you sure you want to copy to.
8192- Are you sure you want to move to.
Hi ckv :D
When you posted those hidden settings bugs I had an inkling that something was afoot.
Your reference reminds me of Xyzzy's very clearly and concisely laid-out Options' descriptions for 1.82.
Good job!
Added in v1.95:
[Compare]
BackColor=
Printjobs with file-name instead ... (2. version)
[Print]
JobPerPage=
Compare Panel: Change background colors?
ckv
Post by ckv »
Clo wrote:...
Thanks Clo. :) Looks like I miseed all the Grid* settings.
marsh wrote:Hello ckv,
Great, thanks. Though I'm not sure if I add ShowAgain to the list. It's kind of hard to use manually, but I still plan to use these flags in my other project. ;)
Thanks. :) I will add these to the list.
marsh
Post by marsh »
Oh, I won't use the ones beyond 'fingers + toes'. I just remove line, and let them all be reset. Good luck with project. :)
262144 - This picture will be converted to RGB with 8bits per component.
Peter2
Post by Peter2 »
ckv wrote: Print:
  • JobPerPage:
    When enabled, XnView adds separate print jobs for each page in multipage files when printing.
    Value: Boolean (1/0), disabled by default
Not only in multipage files. It also works for "batch-plotting" (selecting some single-page file and start the plot command).
Peter
ckv
Post by ckv »
Peter2 wrote:
ckv wrote: Print:
  • JobPerPage:
Peter
Thanks, fixed. :)
GeorgD
Post by GeorgD »
Hi ckv, nice idea :)
Please add a short note where to change this stuff, here a suggestion:
The changes have to be performed in a text editor in file xnview.ini whose location is defined in Options -> System integration. The INI-file contains headings, e.g. "[Browser]", which correspond to the titles below, and you have to place the entries into the right part of the INI file.
You write "See also ColorLabel-# setting", in my XnView.ini there's "ColorsLabels0" - spelling issue or different things?
/Georg
In the XnView Wiki, you can improve the user guide / documentation / F1-help for XnView (classic/Windows) and for XnViewMP
ckv wrote:
  • Companion_00:
    No idea what this one does.
    CopyNameOld:
There are some helpful explanations by andrewj.
marsh
Post by marsh »
ckv wrote: RightButtonFlag:
Area selection with right button instead of left.
ckv wrote: InfoO-# (0-14):
No idea what these do.
Value: Boolean (1/0), enabled by default
Open expanders [+] like one at Properties tab>[+]File.
marsh
Post by marsh »
Another ShowAgain value:
65536 Dialog asking to use tagged or selected files.
(ex. <ctrl + alt + c> in thumbnails view copying to default directory)
drugo
Post by drugo »
wow does it with portable version tool?
ckv
Post by ckv »
GeorgD wrote:Hi ckv, nice idea :)
/Georg
I added a short instructions on the beginning of the list.
I guess "ColorsLabels0" completely different thing. I don't have that setting in any of my ini files. Maybe it's an obsolete setting from some older version.
XnTriq wrote:
ckv wrote:
  • Companion_00:
    CopyNameOld:
I added description for Companion_00, but I didn't see anything about CopyNameOld on that topic.
marsh wrote:Another ShowAgain value:
I updated the list. RightButtonFlag seems to be obsolete setting and I removed InfoO-# as it's not really UI-less.
Thank you guys. :) I do really appreciate all the suggestions you made and I do realize that asking for suggestions is kind of pointless if you don't update when you get them, so I will try to update the list more often from now on.
ckv
Post by ckv »
UI-less Settings documentation is now on the XnView wiki. ==> http://wiki.xnview.com/index.php/UI-less_Settings
Feel free to jump in and edit the wiki page, add stuff, make corrections, fix typos and so on. :)
