How do you make a selection and zoom it in Fullscreen?
r7pkz8sctjn6x90
Post by r7pkz8sctjn6x90 »
From ACDSee I'm used to make a selection with left mouse and then zoom it by clicking inside.
Why is this possible only in Viewer mode and not in Fullscreen mode?
Both right and left mouse buttons only move in Fullscreen.
BTW Why can't unregistered users search the forum?
Re: How do you make a selection and zoom it in Fullscreen?
r7pkz8sctjn6x90 wrote:From ACDSee I'm used to make a selection with left mouse and then zoom it by clicking inside.
You can change the settings in option/General/Keyboard-mouse
We have problems with spams
r7pkz8sctjn6x90
Thank you very much for your quick response.
Which setting is it?
I have Left Button set to "Make Selection" but it only makes the selection when in Viewer, not in Fullscreen mode.
Of course I'm talking about version 1.96.
xnview wrote:
r7pkz8sctjn6x90 wrote:BTW Why can't unregistered users search the forum?
How does disabling SEARCHING for unregistered users prevent spam? Perhaps you thought i said "writing on the forum" instead?
BTW Is there a way to make XnView display thumbnails for .RAM files? It does so for .RM files. When I rename the .RAM to .RM it shows the thumbnail, so perhaps it's just an extension setting?
r7pkz8sctjn6x90
Can you please get help me with the zooming issue?
marsh
Post by marsh »
Selection is accessible in viewer's fullscreen. Press <F11> in viewer or change options:
General>Operations>Mode when starting with a file [Fullscreen - Edit]
General>Keyboard/Mouse>Switching Modes>Use Enter to switch between [Browser > Fullscreen > Viewer]
General>Keyboard/Mouse>Keyboard/Mouse>Left button use in selection [Zoom in]
r7pkz8sctjn6x90
marsh wrote: Selection is accessible in viewer's fullscreen. Press <F11> in viewer or change options:
Thank you.
Too bad that like this I have to press ENTER Twice to go back to the Browser from a zoomed image.
