JPG2000: Message "Contact your Dealer"
ronstephens
Post by ronstephens »
Hi!
I'm trying to convert G4 compressed tiff files to jpeg-2000. BTW, is this the same as JBIG2 that Adobe uses in their pdfs?
When I do this, I get the error mentioned above, "Contact your dealer".
The tiff is 600 dpi. I downconverted them to 300 dpi with Adove Photoshop Elements 3, in case that was the problem. The error then changed slightly. XNView then told me that if I were to convert it, I would lose resolution. I said OK, and THEN it again said this strange error.
What do I do?
THANKS!
-ron
San Jose, CA
Re: JPG2000: Message "Contact your Dealer"
ronstephens wrote:I'm trying to convert G4 compressed tiff files to jpeg-2000. BTW, is this the same as JBIG2 that Adobe uses in their pdfs?
No, jbg2 is not jpeg2000 format.
Your picture is a black&white picture?
ronstephens
Ooops. I guess I wasn't clear enough. Yes, the tif's are 2 bit black and white. I thought jpeg2000 was jbig2. I'm trying to get them to jbig2 because THAT format (jbig2) compresses them between 5 and 10 times TIGHTER than G4!!
Post by Guest »
try JBG or check DJVU .. there some tools that would make JB2.. look for this file..
cjb2.exe
MAAD
Post by Guest »
TRY this link .. it russian.. just look for the cjb2.exe , the link has a viewer to divu which i consider the best in speed and quality..
http://opendjvu.webhost.ru/
MAAD
Anonymous wrote:TRY this link .. it russian.. just look for the cjb2.exe , the link has a viewer to divu which i consider the best in speed and quality..
Links to Russian webpages are a bit dubious, I think. Also you will not be able to read licence agreements or other important things. Could you please try to find a link to an English speaking webpage?
It's good to have other tools which can do the job, but we should try and solve the problems/issues in XnView.
Drahken
Post by Drahken »
The problem seems to be that the jasper JP2K plugin doesn't work with non-truecolor images. Take any greyscale, indexed, or 2-tone image and try to save it as "jpeg2000 jp2 file format" and you'll get the "contact your dealer" message. Convert the image to true color and save it and it'll work fine. On the other hand, you can leave it as greyscale or whatever and save it as a "lurawave jpeg2000 format", and it'll work fine.
Post by Guest »
Luratech supports the grayscale.. but the JASPER supports only color..
but there is another libs..
http://www.ermapper.com/
look for the jp2 sdk.. freeware but it has limit (till 500MB file size)..
http://www.kakadusoftware.com/
and this is my source
http://datacompression.info/JPEG2000.shtml
MAAD
Anonymous wrote:Luratech supports the grayscale.. but the JASPER supports only color..
A bug, JASPER support greyscale too, i'll fix it
