Why do I see in the preview window some pictures rotated, cw or ccw?. When I click on the picture it appears in the right position not rotated.
I use Version 1.96 of XnView with Win XP
thanks for help
Pictures are rotated in preview mode
Re: Pictures are rotated in preview mode
• That's due to some embedded thumb nails which are rotated, so disable the [ ] Use embedded Thumb nail option : F12 >> Thumb nail >> Appearance…
- BTW : This has been explained N… times here in the board, what about using the Search ?
Tinos
thanks for help
tinos
tinos
jaqian
The thumbnail is saved in a different position to the actual picture. If you open the photo in GIMP and re-save with "save thumbnail" option ticked it will correct this.
marsh
An existing thumbnail can also be rebuilt or reoriented without other program:jaqian wrote:The thumbnail is saved in a different position to the actual picture. If you open the photo in GIMP and re-save with "save thumbnail" option ticked it will correct this.
Browser menu>Edit>Metadata>Recreate EXIF thumbnail
(lossless)
or
Options>General>Read/Write>Write>JPEG>[x]Rebuild embedded thumbnail
(saving)
jaqian
Didn't know that... cool feature.marsh wrote:An existing thumbnail can also be rebuilt or reoriented without other program:jaqian wrote:The thumbnail is saved in a different position to the actual picture. If you open the photo in GIMP and re-save with "save thumbnail" option ticked it will correct this.
(lossless)
or
(saving)
dandv
"Rebuild thumbnails" doesn't do anything.
I have a similar problem: thumbnails not being rotated, while the image is. This happened after running PTLens on the image.marsh wrote:An existing thumbnail can also be rebuilt or reoriented without other program:
(lossless)
(saving)
I right clicked the image in Browser, and chose "Rebuild thumbnails", but that command did not do anything. Browser menu>Edit>Metadata>Recreate EXIF thumbnail worked fine.
Is this a bug?
XnView 1.97.2.
Re: "Rebuild thumbnails" doesn't do anything.
"Rebuild thumbnails" is to rebuild thumbnail in thumbnail view from the picture files. It's not the same thing...dandv wrote: I right clicked the image in Browser, and chose "Rebuild thumbnails", but that command did not do anything. Browser menu>Edit>Metadata>Recreate EXIF thumbnail worked fine.
Blutarsky
Disabling embedded thumbs solves the problem, but the browser gets very slow when building .NEF thumbs....
