I made a search but received 0 post.
I opened saved a TIF in two versions: one uncompressed and one with LZW-compression. Filesizes are now as follows:
Uncompressed: 11356 kb
LZW: 12457 kb
So the compressed is larger than the uncompressed. Any explanation or idea?
(Also tested with a screen capture, it works good, as expected - the compressed is remarkably smaller in filesize.)
TIF LZW does not work?
marsh
Re: TIF LZW does not work?
I have similar result. Related topic about LZW + predict having the expected sizes.
Troken
Hi Marsh, thank you for the link.
I have tried to export the image as a compressed TIF, without success. There is no difference between uncompressed, LZW, ZIP or any other compression. The new tif always ends up with the size 12457.
marsh
Export works here with screen capture. There was an old version with export tiff compression bug (don't remember which one).Troken wrote:Hi Marsh, thank you for the link.
I'll look and see if it performs better on a 256 color image.
Could you post the file?Troken wrote: I have tried to export the image as a compressed TIF, without success. There is no difference between uncompressed, LZW, ZIP or any other compression. The new tif always ends up with the size 12457.
Troken
I will post it as soon as I find it. Can not find it right now, it was a while ago.xnview wrote:Could you post the file?Troken wrote: I have tried to export the image as a compressed TIF, without success. There is no difference between uncompressed, LZW, ZIP or any other compression. The new tif always ends up with the size 12457.
