Extract multipage TIFF to other format than BMP
zapoleto
I support and more---
>>zapoleto
Hello !
- Neither the original name nor the original extension are saved in the TIFF / DCX.
- I support your request, enhancing it to the file-name recovering (with or without the original extension as optional)
Kind regards,
¤ Moreover, the original file-names are not retrieved, we get names like :…The page/extract all works great but images are saved as bmp…
Dreamer
Thanks, could you also move that option to File > Extract... (more here)xnview wrote:Ok, i'll add such optionzapoleto wrote:I need to split multipage tiffs. The page/extract all works great but images are saved as bmp. Is there a way to change the format used to save the images ?
