just had to abandon the batch processing of cr2 files on something because
the results didn't match the input parameters at all. not even close.
all i was doing was crop, levels, save to tga format in a separate folder.
i used xnview crop tool to determine x/y positioning. when i put those
numbers into the crop parameters in the batch tool i got something which
did not match my positioning at all. (v1.96)
i had recently done the same thing with jpg to jpg processing and it worked
fine so it would appear that this might be specific to cr2 files. bummer.
thanks,
BabaG
						batch processing canon raw cr2 files
Dual settings?
Mismatched settings can produce a different result when comparing converter to viewer.  With General>Read/Write>Read>Camera RAW [x]High resolution setting and View>Misc>Camera RAW>Full size, I had identical results for x:512 y:512 W:512 H:512 crop.  Output was png.
						Re: batch processing canon raw cr2 files
that seems to have been it.  thanks a lot!
BabaG
						BabaG
