DPI changed after creating a multipage TIFF
eL_PuSHeR
Post by eL_PuSHeR »
Why is dpi set to 72dpi when the original files were 300dpi? Why XnView changes it?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
Re: DPI changed after creating a multipage TIFF
eL_PuSHeR wrote:Why is dpi set to 72dpi when the original files were 300dpi? Why XnView changes it?
In jpeg, you can have 3 fields to set dpi.
Do you option/general>use exif dpi...
eL_PuSHeR
Post by eL_PuSHeR »
The source files are TIFF.
Okay. I have marked that option. I see it's working now, at least when adding JPEG and PNG files.
Thank you very much.
PS - I am wondering why that option is disabled by default.
Intel i7 5960X
8 GB DDR4 (2100)
