Error: 'Fehler in Anwendung' --- often it comes back
ftomasch
XnView 1.96.1 does not function correctly. The programme is closing suddenly.
When I click on a Folder in "Browser " or in the the "Categories" comes up the mark "failure" - I add it here below. Then XnView is or gets closed. This failure appears by chance.
What could it be?
Best regards.
xnview.exe - Fehler in Anwendung
Die Anweisung in "0x004135b0" verweist auf Speiher in "0x01ece155". Der Vorgang "resd" konnte nicht auf dem Speicher durchgeführt werden.
Klicken Sie auf "OK", um das Programm zu benden.
What could it be?
Best regards.
Re: xnview.exe - Fehler in Anwendung
Could you try to start with a clean xnview.ini?ftomasch wrote:XnView 1.96.1 does not function correctly. The programme is closing suddenly.
ftomasch
Thank You Pierre!
XnView works perfektly
ftomasch
The Return --- Error: 'xnview.exe - Fehler in Anwendung'
Unfortunately it was not a long time that XnView worked. Whenever I delete the data INI, XnView works again. You cannot say when the failure will happen. Probably it is by chance. Is there any possibility to avoid the failure?
Best regards
Franz
Best regards
Franz
Re: The Return --- Error: 'xnview.exe - Fehler in Anwendung'
You have again the problem?ftomasch wrote:Hello,
ftomasch
Re: Error: 'Fehler in Anwendung' --- often it comes back
Yes, it is the same problem and it happens frequently but irregularly.
Best regards
Franz
Best regards
Franz
Always on the same folder?ftomasch wrote:Yes, it is the same problem and it happens frequently but irregularly.
ftomasch
No, in different folders and categories
If you remove the .ini, xnview works?ftomasch wrote:No, in different folders and categories
ftomasch
No.
At first, I quit XnView.
Then delete .ini.
Then start Xnview again. It works perfekt a few time.
Suddenly the failure comes again in a Categorie or a Browserfolder
Best regards
Franz
Then delete .ini.
Best regards
Franz
Do you change something in Category?
ftomasch
No, I don´t change anything in Categorie
Franz
Franz
And if you disable thumbnails caching?
ftomasch
No, thumbnails caching is enable
Could you trying to disable it?ftomasch wrote:No, thumbnails caching is enable
