Plugin for viewing zip and rar archives as folders
jimvj
Post by jimvj »
I'm sure this topic is covered somewhere on your site, but I have not been able to find it.
I downloaded Zip32.dll and placed it in the .../xnview/plugins folder.
Info on plugins shows that Zip32.dll is recognized as "Zip Archive Encoder"
with copyright from Info-ZIP.
But when I double click on a zip archive in the browser, Xnview shows
the first file in the zip archive. I would like it to open the zip archive as
if it were a folder; which would then allow me to view any file in the archive.
What am I doing wrong?
Thanks
marsh
Re: Plugin for viewing zip and rar archives as folders
Post by marsh »
Hello, try highlighting file in browser and pressing <F11>. Browser's fullscreen has different functions than viewer's.
jimvj
Post by jimvj »
Hi Marsh:
F11 does nothing when a zip or rar file is selected.
If I select a jpg file and hit F11, the image opens in fullscreen mode.
Thanks
marsh
Post by marsh »
jimvj wrote:Hi Marsh:
Thanks
ok, press <enter> to open archive, followed by <F11> on image. Then navigation will be possible from one image to another.
dlls should go in program's "AddOn" subdirectory (if using newest version).
Options>General>Keyboard/Mouse>Open Action>Archives [x]Open in XnView
jimvj
Post by jimvj »
Hi:
I moved the zip32.dll to Addons.
The options...Archives [x]Open in XnView is/was this way
I am using version 1.96.1 (May 13 2009)
I am using Vista Home Premium with a 64 bit Intel processor.
(I would guess that all 32 bit programs will run correctly on a 64
bit processor; though the reverse may not always be true.)
I still have not been able to get zip or rar files to be expanded
in XnView. Is this topic discussed somewhere in the Xnview
documentation?
Thanks
marsh
Post by marsh »
jimvj wrote: I moved the zip32.dll to Addons.
Compress and view are seperate downloads. The following is for viewing:
Contents of archive.zip, at http://www.xnview.com/en/addons.html
7z.dll
sqx20.dll
UNACEV2.DLL
unrar.dll
Unzip32.dll
jimvj
Post by jimvj »
Thanks.
One more question:
How do I setup XnView so archive files do not show up in the folder tree?
jimvj wrote: How do I setup XnView so archive files do not show up in the folder tree?
archive are shown in tree view???
ckv
Post by ckv »
Yes, in Windows Vista zip archives are shown in the folder tree. It's painfully slow when expanding a folder with bunch of zip files.
Option to disable this behavior (if it's even possible) would be nice.
Hum, strange. I don't add zip in the treeview, so perhaps it's an option in windows explorer??
  • Download deskew_sample.zip and put it into an empty folder.
  • Create a subdirectory and copy deskew_sample.zip there.
XnView v1.96.5 (top) & XnView MP v0.20 (bottom) @ Windows 2000 SP4:
  • Image
Is this a bug or a feature?
XnTriq wrote:Is this a bug or a feature?
On same pc?? You should have an extension in windows explorer for that...
My screenshot shows XnView-win-full.zip & XnViewMP-win.zip on the same PC, and I don't have any extensions installed that would make Explorer treat archives like folders.
I've seen similar behavior of XnView v1.96 with some PowerPoint and Acrobat documents. It seems that PDFs/PPTs/ZIPs are identified as “JPEG based files”, if XnView finds a JFIF header at the beginning.
Tools » Options... » Browser » File List » Misc.:
  • [ ] Recognize only by extension
    Scan file headers in folders: [ Always ]
XnTriq wrote:I've seen similar behavior of XnView v1.96 with some PowerPoint and Acrobat documents. It seems that PDFs/PPTs/ZIPs are identified as “JPEG based files”, if XnView finds a JFIF header at the beginning.
Update: The images in a ZIP archive have to be uncompressed/stored for this “feature” to work.
ckv
Post by ckv »
XnTriq wrote:Update: The images in a ZIP archive have to be uncompressed/stored for this “feature” to work.
I guess you also have unchecked the "Recognize only by extension" option.
XnView finds a jpeg file from the zip because the files are not compressed in the zip. So I guess it's an unintended feature made possible by other features... Kind of cool, actually. :)
Edit: Uh-oh, I just saw the configuration in your post below.
Also, this works without the unzip plug-in too.
