Removing Metadata without Saving
checkerfred
Post by checkerfred »
Can someone tell me how to do this? I tried the clean metadata option but it does nothing to my image.
Edit...weird...its working now
Dreamer
Re: Removing Metadata without Saving
Post by Dreamer »
In Browser select images (you can search pictures in more folders and click "Browse", then select images), in menu > edit > metadata, choose "clean" - is that what you've tried? It works perfect here.
Dreamer
Works here.
The irritating part is that you have to tick the checkboxes for deletion. One would rather expect that you tick the checkboxes of the metadata you want to keep.
helmut wrote:The irritating part is that you have to tick the checkboxes for deletion. One would rather expect that you tick the checkboxes of the metadata you want to keep.
Really? better to have the data to keep?
Dreamer
Post by Dreamer »
I'm not sure about this. If "clean" is selected, then you should select what to clean/remove. Of course the checkboxes are not optimal, [x] would be better maybe, but when you change it now, it would be confusing for existing users IMHO.
Dreamer
