How do I change the color shown after deleting part of pic
c627627
Post by c627627 »
When I select and delete part of a picture, the deleted part is shown in black, how do I change it to white?
marsh
Re: How do I change the color shown after deleting part of pic
Post by marsh »
For true colour images:
Viewer menu>Edit>Background colour...
c627627
Post by c627627 »
Using XnView 1.93.4 (last version before Automatic updates were introduced which freeze the program if firewalls prevent it from accessing the internet)
There is no View > Edit
XnView 1.93.4 has Tools > Options > View > Background color
but that only changes the outside background color, not the color of what's left after you select the area inside the pic and press Delete.
marsh
In newer version
Post by marsh »
Image background color is in menu of v.1.96.1
c627627
Post by c627627 »
OK I upgraded to 1.96.1 just so that we're on the same page.
only changes the background color.
If you select part of the picture with your mouse and press the delete key, the deleted part is still black, see what I mean?
marsh
Post by marsh »
c627627 wrote: If you select part of the picture with your mouse and press the delete key, the deleted part is still black, see what I mean?
There are similar names throughout program. Here, a gold colour is chosen in menu for backing when a portion is deleted:
c627627
Post by c627627 »
Thanks buddy.
So it was Edit > Background Color
Thanks.
