Hello.
I used to use xnview regularly on my old laptop to get mt ST graphics to the PC.
Installed latest version on my new pc along with all extensions & shell but it will not see any of the Degas format files, when I try to load them it says "Format of the file XXX could not be determined"...
Am I being a complete tool? I don't remember having to do anything special before to use Degas files...
pls help!
pea
Degas PI1
marsh
Re: Degas PI1
These topics might still be relevant:
How can I convert .pi2 files to something windows can view?
Support for pi2 files
Degas Elite PI1 format
pea
Re: Degas PI1
Thanks, I looked at shw's post of AF & several others.marsh wrote:These topics might still be relevant:
This version I d/l from the site does not correspond to this info. I have used several versions of xnview before & not had this problem.
Here are some screen shots of what I can see:
I might be having a really bad day (it feels like it) but I cannot see a mention of degas anywhere...
I installed XnView-win-full.exe, a ~12mb file
Hope you can help, ta
marsh
Re: Degas PI1
The name of the option has been changed to:
General>Operations>[x]Display all image file types
(I see pi1 thru pi6 in list)
pea
Re: Degas PI1
I checked with a friend - he had many more in his lists than I had.marsh wrote:The name of the option has been changed to:
I took the .ini file from his older version & now it works. Maybe something is b0rked in that latest install? Maybe something just went wrong? Either way, I can now use .PI1 files on my new PC which is the best reason to own xnview for an ST kid like me
Thanks for your time.
marsh
Re: Degas PI1
I used an Atari 800 for games. Never got the chance to play with an ST. Good luck with the images.
grazey
Re: Degas PI1
well i've installed it on a brand new laptop and the PI1 file types no longer exist
I'm sure this must be a problem in the latest version.
Grz
Grz
Re: Degas PI1
Do you have enabled option/General>Display all formats?grazey wrote:well i've installed it on a brand new laptop and the PI1 file types no longer exist
grazey
Re: Degas PI1
Yes
THe only way I've managed to get it working is using an old INI file from my old Desktop
Grz
Grz
Re: Degas PI1
Strange, it's the setting that enable degas loading...grazey wrote:Yes
Re: Degas PI1
Perhaps the .ini file was read-only. Just a guess...grazey wrote:THe only way I've managed to get it working is using an old INI file from my old Desktop
