Disable raw files
neoneuf
Disable raw files
Post by neoneuf »
Is there a way to make xnview ignore raw files ?
I have in the same directory raw and jpeg files and I'd like to see only jpeg files in particular in the diaporama.
Thanks.
Re: Disable raw files
neoneuf
Post by neoneuf »
OK Thank you.
Unfortunately it doesn't work with the slideshow (diaporama).
If you select 2 folders and start the diaporama, the raw files contained in the 2 folders are displayed
even though they are not visible in the browser...
