Cineon conversion
prost84
Cineon conversion
Post by prost84 »
If I use Xnview to export a file in cineon format (.cin, .dpx) in a standard format like TIFF, is there any quality loss?
If so, what can I do in order to avoid it?
Thank you
Re: Cineon conversion
The cineon file has more than 8bits per component?
prost84
Post by prost84 »
yes, ten bit per component but it is log scale....
prost84 wrote:yes, ten bit per component but it is log scale....
XnView convert always picture in 8bits
