Make backups easier
Amamba
Make backups easier
Post by Amamba »
I want to backup the few files that contain my categories, user settings, descriptions, etc.
It would really help if there was a way to specify a default directory for them, e.g. "Xnview->User Data". It would help even more if they all had the same extension, e.g. ".xud" for "XnView User Data". This way, a backup could be very easy to set up via MS Sync Toy.
Thanks !
Re: Make backups easier
user settings & db file can be in the same folder...
Amamba
Post by Amamba »
