JPEG quality slider moves the wrong way on keyboard input
TheEvilHammer
Post by TheEvilHammer »
To repro:
  1. Open Tools → Options → General → Read/Write.
  2. Select the Write tab and then select JPEG.
  3. Use the mouse to put the current focus on the Quality slider control.
  4. Press the up key and the quality decreases; press the down key and the quality increases.
Re: JPEG quality slider moves the wrong way on keyboard input
"Confirmed", but I'm not sure whether this is really a bug:
Sliders' value increases by pressing "Down" this is Windows standard. Now, Pierre has combined two controls: The slider and editext with spinbutton. Pressing down while focus is on the slider increases the value whereas pressing down in the edittext decreases the values.
In order to make this combined control work consistently it might make sense to change the slider behaviour, but this would be no longer Windows standard, then. And it might be quite some effort, because the combined control is used in many dialogs, in "Image > Adjust > Brightness.." for example.
All in all I'd say this is a small nuisance - but also the little things working properly make up a good software...
TheEvilHammer
helmut wrote:Sliders' value increases by pressing "Down" this is Windows standard.
Are you sure this is true? I just tried it out and I'm not seeing that behavior. Open Control Panel → Sounds and Audio Devices and you'll see a horizontal slider. If you press Down while the focus is on the slider, it moves to the left, which is exactly what I would expect. Why do you think that the Windows standard is the other way around?
:arrow: TheEvilHammer
:) Hello !
…Open Control Panel → Sounds and Audio Devices and you'll see a horizontal slider. If you press Down while the focus is on the slider, it moves to the left, which is exactly what I would expect. …
• I confirm this. Keys:
Down (or left) Image Minus
Up (or right) :arrow: Plus
- That work by steps (with an irritating “beep” for each key press).
BUT :
… 4. Press the up key and the quality decreases; press the down key and the quality increases. …
• I cannot confirm that in XnView 1.96.5 ! Here, it works as expected in this dialogue-box (and also i.e. in the Adjust… ones).
- XP-Pro SP1 (Fr)
:mrgreen: KR
TheEvilHammer
Clo wrote: • I cannot confirm that in XnView 1.96.5 !
I am actually running 1.96.2, so maybe the problem has been fixed? I will upgrade and try again...
TheEvilHammer
I just tried 1.96.5 and I'm seeing the same problem.
I've just double-checked with some applications and found that there seems to be no real standard for the Up/Down keys. Some applications (e.g. Logitech Quickcam or old Windows Common Controls slider) use "Down" for a higher value, some applications like the volume control of Windows use "Down" for a lower value.
Using "Up key" for a higher value and "Down key for lower value is more logical, especially in combination with the edittext/spinbutton. So if possible (and not too much effort) this should be changed.
I've tried with 1.96.5, and up increase
How to reproduce:
  1. Place the mouse cursor inside the field with the spin box controls.
    • Up arrow key = increases value
    • Down arrow key = decreases value
    • Left arrow key = no action
    • Right arrow key = no action
  2. Click on the slider control.
    • Up arrow key = decreases value :bug:
    • Down arrow key = increases value :bug:
    • Left arrow key = decreases value
    • Right arrow key = increases value
Same behavior:
  • File » Export... » JPEG » Quality
  • Tools » Options... » General » Read/Write » Write » JPEG » Parameters » Quality
__________________________________
XnView v1.96.5 @ Windows 2000 SP4
[/list]
It's not a bug, but the standard behaviour
TheEvilHammer
I think the consensus is that this "standard behavior" is not intuitive and doesn't match up with Windows, which is why we're suggesting the change.
TheEvilHammer wrote:I think the consensus is that this "standard behavior" is not intuitive and doesn't match up with Windows, which is why we're suggesting the change.
I can't change it, it's the standard behavior of this windows control :-)
TheEvilHammer
Oh, I see what you're saying now. Really? That's very odd, considering that I've used other slider controls in Windows that didn't work that way...
ckv
Post by ckv »
TheEvilHammer wrote:Oh, I see what you're saying now. Really? That's very odd, considering that I've used other slider controls in Windows that didn't work that way...
There is no need to be disrespectful.
xnview wrote:I can't change it, it's the standard behavior of this windows control :-)
There's a trackbar control style called TBS_DOWNISLEFT (0x0400) that will reverse the up and down keys.
TheEvilHammer
What are you talking about? I was not being disrespectful to anyone. All I was saying was that I've seen the opposite behavior in Windows, which is merely an observation, and it contradicts what Pierre has noticed, making the situation "very odd", as I said.
