No 'Image' item in main menu
belzecue
Post by belzecue »
I am really stumped by this: I no longer have an IMAGE item in my top menu. Here's what I have:
FILE | EDIT | VIEW | TOOLS | CREATE | WINDOW | INFO
There used to be an IMAGE item, and this is confirmed in the HELP documentation:
How To Increase or Reduce the Size of an Image:
• Open the image file.
• Choose the Menu item Image > Resize.
I checked OPTIONS and can't see anywhere I might have turned it off somehow...
XnView version: 1.96.5
OS: Win7-64
jpmccormac
Re: No 'image' item in main menu
Post by jpmccormac »
In my Windows XP version 1.96.5 there is a menu item for IMAGE - between View and Filter.
belzecue
Post by belzecue »
:? You know, I've been using XnView for so long... yet I did not realize the IMAGE menu item only shows up when you are on an active image tab! I was in the Browser tab -- that's why it was not showing up! I was clicking on the image preview and expecting to see the Image item in the top menu so I could resize it. But you have to open the image first by doubleclicking on it.
So, false alarm. Thanks for your reply, jpm...
