Hello Pierre et al,
I routinely use the web page creation function of XnView and very much appreciate the quality of the thumbnail images that are produced.
I have been trying to create the equivalent thumbnails (to the web page creation function) using the XnView batch function. Unfortunately the quality has not been as good as the "web page create" output.
Therefore, I would like to know what steps are performed to create the high quality "web" thumbnails, especially the sharpening process.
Thanks
PETER
Creation of high quality thumbnail images
PSHRutPark
Re: Creation of high quality thumbnail images
It's only a resize + sharpen (if used)
PSHRutPark
OK. Thanks Pierre.xnview wrote:It's only a resize + sharpen (if used)
Yes, I use the sharpening option.
For the resizing, what type of "resampling" do you use?
PETER
bilinearPSHRutPark wrote: For the resizing, what type of "resampling" do you use?
PSHRutPark
Thanks for your replies.xnview wrote:bilinearPSHRutPark wrote: For the resizing, what type of "resampling" do you use?
Maybe the resampling mode accounts for the difference. I will try bilinear.
PETER
