Add "Focus mode" to the list of EXIF-image options
XnKris
Post by XnKris »
I am surprised that Focus Mode (ie, AF or Manual focussing) isn't listed in the list of EXIF attributes when you click on EXIF-image (in Options/View/Fullscreen). Is there some problem with adding this? I'm sure it must have come up before, although I couldn't find it in a search of Suggestions.
regards, Kris
Re: Add "Focus mode" to the list of EXIF-image options
Focus mode is in Makernotes?
XnKris
Post by XnKris »
xnview wrote:Focus mode is in Makernotes?
I'm not sure how to view Makernotes. When I look at the EXIF information (I have Xnview 1.96.2) it has a section at the top called Camera, then another longer section called Image. "Focus Mode" isn't in either of those, but I can't see "Maker Notes". It is probably just my ignorance, but can you tell me how to see maker notes?
Thanks, Kris
In the EXIF view, you can see if it's in Camera/Image or Makernotes
