"I don't know how to read" creating PDF (multi)
eL_PuSHeR
Post by eL_PuSHeR »
Hello.
When merging multiple PDFs via "Create multipage file", Xnview will throw an error message saying that "I don't know how to read" certain PDF when reaching a multipage one. The option "All pages/images" is ticked.
Here is one small example PDF. Try to merge it to others...
http://depositfiles.com/files/yoxt3w5ff
Best regards.
EDIT: Forgot to say I am using v1.96.5 under WinXP.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
GeForce GTX 970 (Gigabyte)
Re: "I don't know how to read" creating PDF (multi)
I have not problem. Do you have ghostscript?
eL_PuSHeR
Post by eL_PuSHeR »
Yes, I have ghostscript 8.70 installed.
Funny enough, Xnview can open the PDF file without problems manually. It even warns me it's a multipage one.
WEIRD! Try to merge this file with the previous one, it throws a "not enough memory" on my home computer.
PS - When I have time, I am going to do a CLEAN INSTALLATION and try again...
EDIT: After doing a clean installation, I get another different error.
Intel i7 5960X
8 GB DDR4 (2100)
Ok, there is a problem to load all pages for S561770-03SO.pdf...
eL_PuSHeR
Post by eL_PuSHeR »
Glad to know and thanks for taking your time looking into this.
Regards.
Intel i7 5960X
8 GB DDR4 (2100)
